4 kanaals amp lab/camco
  • jack
    • 1090
    #31
    Correctie: de gain blijft wél constant... !
    met gain bedoel ik de gemeten gain van de NX 242 natuurlijk..
    ps low cut Staat uit!
    JVM sound de NEXO specialist
    • Husss
      • 220
      #32
      En bij deze de white paper!
      PS heb ook de 4x4 overwogen. dit laat echter nog op zich wachten en gezien de goede ervaringen met lab ben ik toch voor de 10.000Q gegaan.
      20.02.2007 • Page 1 of 1
      File: Nexo_NX242_Compatibility.doc.doc
      Compatibility of Lab.gruppen Class TD Power Amplifiers
      and Nexo NX242 Digital TDcontroller
      Issues:
      Nexo's NX242 requires and monitors a certain stable amplifier gain. Users in the field have
      reported that with a number of different amplifier brands and models in the market the
      NX242 indicates gain deviations.
      Among these amplifiers are Lab.gruppen Class TD amplifiers such as
      • all of FP+
      • fP 6400 and fP 3400
      • C Series, except the "X" line extension models
      Test:
      We have tested the NX242 with Lab.gruppen Class TD amplifiers and were able to reproduce
      the symptoms as reported. It appears that depending on frequency the NX242 indicates
      significant deviations from the desired amplifier gain.
      The error indication cannot be disabled on the NX242.
      However, the NX242 does not change its audio performance, e.g. by compensating for these
      errors.
      Analysis/Results:
      The amplifiers used for testing performed flawlessly throughout the test and are known and
      praised in the market as such. Factually, although the NX242 indicates gain deviation the
      gain of the Class TD amplifiers remains stable at the chosen value.
      Our tests have shown that the NX242 seems to misinterpret other information, and that the
      gain sensing method utilized by the NX242 causes the unit to falsely indicate errors even if
      there are none. Our testing further demonstrated that false warnings are triggered if the
      program material has content where the phase response of the amplifier is greater than 5
      degrees.
      High or low pass filters, as often used in amplifiers at the extreme ends of the audible
      frequency range, can eventually cause differing errors depending on frequency. Although
      they have virtually no audible effect, filter roll-offs of this type may be read by some external
      processors as gain deviations at very low or very high frequencies.
      With the gain deviation as indicated by the NX242 being a “warning” only, and not resulting
      in any actual changes to the audio output of the amplifier, any long-term solution can only be
      implemented by the controller's manufacturer Nexo, most likely by a firmware modification.
      In summary, our testing indicates that Lab.gruppen Class TD amplifiers can still be used
      along with the NX242 provided that the user trusts the amplifiers and is comfortable with
      ignoring the error messages, and/or has alternative ways of monitoring amplifier
      performance, e.g. via Lab.gruppen's NomadLink® remote monitoring system.
      • jack
        • 1090
        #33
        Vanavond heb ik een feesje
        Als subs 4x ls500 2x origineel 2x imitatie(alle 8ohm)
        tops 4 x Nexo PS10.
        Nexo processor (nx 242)
        eens kijken of hij warm wordt?
        • purplehaze
          • Jul 2004
          • 692
          #34
          Heeft iemand de 4-kanaals camco's nu al eens getest en evt. vergeleken met Lab Gruppen 4-kanaals bakkies?
          Het gaat om 1 van de volgende
          [FONT=Arial][FONT=Arial]Qpower 4, 4 x 1000W / 4 Ohm[/FONT][/FONT]
          [FONT=Arial][FONT=Arial]Qpower 6, 4 x 1500W/ 4 Ohm[/FONT][/FONT]
          [FONT=Arial][/FONT][FONT=Arial][FONT=Arial]Qpower 10, 4 x 2500W/4 ohm [/FONT][/FONT]
          • Turboke
            • Oct 2006
            • 463
            #35
            denk dat je eerder zal moeten uitgaan naar de vermogens van
            840w voor de q4
            1000w voor de q6
            1800w voor de q10
            meen eens ooit gelezen te hebben dat de andere vermogens zo zijn als ze maar op 1 kanaal spelen
            • Koen van der K
              • 1146
              #36
              Heb vorige week op verzoek van 'n klant 'n aantal nieuwe amps hier op de testbank gehad waaronder 'n Macrotech 9000i en 'n Lab FP10000Q.
              Qua meetresultaten haalt 't allemaal de specs wel (verwacht ook niet anders in deze prijsklasse); qua klank echter aanzienlijke verschillen tussen de 9000i en de 10000, met name in het (sub)laag waar de MA9000i volgens betreffende klant beduidend minder presteert. Vergelijk met 'n Camco oid heb ik (nog) niet, misschien kan Jack er een regelen ?
              Groeten !
                #37
                840w voor de q4
                1000w voor de q6
                1800w voor de q10
                Wat je schrijft klopt inderdaad, geloof wel dat het voor 2 kanalen geldt.
                Één versterker moet je dus niet op alle vier kanalen met subs belasten maar bijvoorbeeld twee kanalen sub, één kanaal mid en één kanaal hoog.
                • Koen van der K
                  • 1146
                  #38
                  Klopt, staat ook in de door Lab opgegeven specs en het komt overeen met wat ik heb gemeten. Hoe lager de impedantie hoe sneller de amp buiten adem is. Alle vier de kanalen voor sublaag gebruiken is (theoretisch) niet aan te raden maar in de praktijk blijken de Labs zich goed staande te houden.
                  Groeten !
                    #39
                    Heb je ook een vergelijking met een LAB4000 of FP6400?
                    Ben erg benieuwd hoe de FP10.000 zich houdt.
                    • Turboke
                      • Oct 2006
                      • 463
                      #40
                      de fp 6400 zullen altijd wel beter gaan en ook kunnen deze op 2ohm presteren wat de meeste 4 kanaals amps niet kunnen.
                      denk dat 2 fp 6400 wel beter presteren dan 1 - 10000
                        #41
                        De FP10.000 kan ook gewoon op 2 Ohm.....
                        De FP6400 en de LAB 4000 leveren 3200W/ch @ 2Ohm en de FP10.000 2500 Watt. Dat verschil is zo klein dat het niet hoorbaar is.
                        Het gaat erom of er, behalve dan dat verschil in vermogen, nog meer verschillen in zitten.
                        Overweeg op termijn mijn rackje met LAB4000's en 1600's te vervangen voor 2 FP10.000 maar vraag me af of ik voor het sub er beter aan doe om mijn oude vertrouwde 4000's daarvoor te blijven gebruiken en alleen voor het mid/hoog een 10.000 te pakken.
                        • flurk
                          • 409
                          #42
                          tops 4 x Nexo PS10.
                          Zijn de LS 500 niet standaard 4 ohm?
                          • Turboke
                            • Oct 2006
                            • 463
                            #43
                            Da klopt dat ze werken op 2 ohm maar wat heb je eraan als dit niets opleverd.
                            Trouwens heb ik ook al horen zeggen dat de 10000 middenklas amps zijn en dit door mensen die op de firma werken waar ze verdeeld worden.
                            • Koen van der K
                              • 1146
                              #44
                              Helaas heb ik de andere labs niet op de testbank gehad. Ik heb de meetresultaten van de FP10000 zo niet bij de hand maar het is iets in deze trand; Gespecificeerd vermogen kan bij 2 kanalen 8 Ohm belast gedurende ca. 1 sec worden geleverd, daarna zakt de output ca. 3dB in (halveert dus). Bij 2 kanalen 4 Ohm of 1 kanaal 2 Ohm haalt-ie krap de specs en zakt binnen 0,5 seconde de output 3dB terug. Ik had geen dummyloads meer voor de overige 4 kanalen anders had ik dat ook wel even gemeten . THD+N en andere meetgegevens blijven allemaal netjes binnen spec.
                              Let wel dat bovenstaande meetgegevens zijn verricht met sinusvollasttest, geen praktijksignaal dus maar wel handig om vast te stellen hoe lang de adem van 'n amp is voordat deze z'n vermogen terugregelt. In de praktijk (muzieksignalen) ligt dat natuurlijk anders.
                              Groeten !
                              • arie
                                • Feb 2003
                                • 550
                                #45
                                Hoi Koen,
                                Ik heb de fp10000 in de praktijk naast onderandere de fp6400 gehad en moet zeggen dat die het dan toch echt niet slecht doet. Kwa openheid in het geluid is die beter dan een fp6400 (mits je hem niet volledig aan 2 ohm belast, dan presteerd de fp6400 weer beter). Ik heb heb een maand geleden een keer met twee fp10000 gedraaid (normaal gebruiken we voor subs fp7000) nu 1 fp10000 gebruikt voor laag/mid mid en hoog en de andere fp10000 volledig op 4 dubbel 18" subs 4 ohm(eaw sb750). Dit ging verrassend goed, had zelf niet echt het gevoel veel minder power te hebben als met 2x fp7000 op de subs. Groeten Arjan
