db technologies, qsc of alto versterker
  • henkie-penkie
    • Feb 2009
    • 5
    Hallo
    Ik ben op zoek naar 2 nieuwe versterkers voor mijn topjes (jbl eon 1500 225W rms bij 8Ohm), en bleef mijn oog vallen op de volgende 3 versterkers
    Mijn budget is ongeveer 350,- per versterker
    welke versterker zou hier het meest geschikt voor zijn?
    dB Technologies HPA 1000
    dBTechnologies’ HPA series power amps deliver high performance and quality at an astonishingly affordable price. Designed for professional use in touring racks as well as for fixed installation, the series comprises four Class-(HD) models that deliver 2x 510 W/RMS to 2x 1050 W/RMS at 4 ohms. Featuring Class-(HD) technology with and weighing just 14 kg, the flagship HPA 3100L power amp delivers up to 3400 W/RMS output. It comes with a PFC switched-mode power supply.
    Engineered for utmost ease of use, these amps offer connection options - XLR inputs for patching in signals as well as Speakon ports for connecting speaker systems. What’s more, their extensive protective circuits ensure reliable, safe operation.
    Specifications.
    Class-(HD) technology to minimize thermal load and maximize efficiency
    Fast response and dynamic sonic image with lowest distortion factors
    Easy to configure in mono/stereo/bridge modes
    Extensive protective circuits ensure high reliability and operating safety
    Front panel signal and clip and protect LED indicators
    Operable at 2 ohms
    Speakon connectors
    2 HU, 19“, low weight for easy transportation
    Switchable limiter
    Technical data.
    Power output, stereo, RMS @ 2 ohms -
    Power output, stereo, RMS @ 4 ohms 2x 510 W
    Power output, stereo, RMS @ 8 ohms 2x 330 W
    Power output, bridged, RMS @ 4 ohms -
    Power output, bridged, RMS @ 8 ohms 1x 1020 W
    Amp class Class-HD
    Power supply Conventional
    Frequency response 20 - 2000 Hz
    THD @ 1 kHz 0.05%, 1 dB below clip
    Damping factor @ 8 ohms >300
    Slew rate 50V/μs
    Signal-to-noise ratio 105 dB
    Input sensitivity 26 dB / 32 dB / 1.4 V
    Input impedance 20 kOhms bal./
    10 kOhms unbal.
    Protective circuits Temp., DC,
    RFI, short-circuit
    Inputs 2x XLR male/female
    Outputs 2x Speakon
    Cooling Temperature- Temperature controlled fan
    Dimensions (W x H x D) 482 x 89 mm x 402
    Rack height 2 HU
    Weight 15 kg
    €330,-
    Alto Mistral 1500
    Powerful and musical! Mistral amplifiers are based on a very musical sophisticated AB design and are available in a wide range of power from 400 to 2800 watts. These amps include a soft start, a signal limiter (which can be switched off) a variable speed low-noise fan and a sophsiticated LED meter display monitors the amplifiers operation status in real time. The Mistral Series amplifiers also include an LED meter for every channel and functions monitored include: Operation, Limiting, Clipping and Protection modes. All Mistral toroidal transformers include an independent secondary rail for better stability and dynamic range.
    ‧RMS (EIAJ) power: 2×320W @8Ω; 2×540W @4Ω; 1×1000W @8Ω
    ‧Binding post and Neutrik Speakon output connectors
    ‧Smart-design protection system
    ‧High-current toroidal transformer
    ‧Balanced XLR inputs/ parallel outputs
    ‧Variable speed cooling
    ‧4 LEDs for operation/protection, limit, power on and clip
    ‧Dimensions (W×D×H): 483×400×89mm (19"×15.9"×3.5”)
    ‧Weight: 13kg (28.7 lb)
    €359
    QSC GX3
    2x 500W/4Ohm
    2x 350W/8Ohm
    Input: XLR, RCA and 1/4" Jack
    Out: Speakon Combo for 1/4" Jack and Speakon
    weight: 11,5 kg
    €333,-
  • sis
    • 3305
    Denk dat QSC al het meeste bewezen heeft dat ze goed en roadproof zijn in vergelijking met de andere 2 genoemde merken .
    Ik heb zelf altijd QSC gehad, meer dan 10 jaar lang , geen enkel probleem mee gehad.
    sis
    • nightline
      • 1001
      Inderdaad, gewoon voor de QSC gaan, als je een beetje bekend bent in de (semi) pro audio is dit geen keuze maar wetenschap....
      Mvg
      Jack
      Powered by AudioMadness....
      • DJ_Progrezz
        • Apr 2008
        • 104
        Je krijgt er bij s2store nog eens 6 jaar garantie bij, gewoon die QSC nemen dus. Kans is wel dat zo'n goedkope QSC intern niet veel verschilt van pakweg die Alto.
        • sis
          • 3305
          Als je 6 jaar garantie krijgt zou ik zeker niet twijfelen.
          sis
          • henkie-penkie
            • Feb 2009
            • 5
            Ik heb er vandaag 2 besteld bij s2store, bedankt voor de reacties
            • Roelande
              • Jan 2009
              • 140
              dB Technologies ASX 18
              om in het rijtje van db technologies te blijven:
              ik ben van plan om een dB Technologies ASX 18 actieve crossover te kopen.
              Het belangrijkste argument hiervoor is het feit dat er niet ongewenst kan geprutst worden aan de knoppen...
              Ik weet wel dat ik er zelf ook aan moet kunnen maar eenmaal goed ingesteld veranderen de instellingen niet meer...
              goede keuze of niet?
              Roeland
              • DjDennizz
                • Apr 2006
                • 18
                Roeland
                Makkelijke Keuze, en inderdaad wel een goedkope keuze. Simpel basic ding wat zijn werk perfect doet. Voor rond de € 125,- een goede crossover.
                Met meer instellingen zou ik anders kiezen voor de DSX24. Maar die zit alweer op een ander prijskaartje.
                • Roelande
                  • Jan 2009
                  • 140
                  4 keer duurder dus :-)
                  ik heb niet echt behoefte aan een management unit dus ga ik voor de ASX18 gaan.
                  thx,
                  Roeland
                  • sis
                    • 3305
                    Even een vraagje .
                    Je hebt hopelijk nu 2 QSC's ?
                    Hoe is de ervaring ?
                    sis
                    • MusicSupport
                      • 1016
                      Goeie keus Henkie
                      Heb hier ook 2x GX3 (35KG) in een rackje om zo mee te pakken zodat ik geen rack met 3 P1050 (100KG) hoef mee te slepen.
                      Ben dik tevreden. Voor een lowbudget versterker doet tie het erg goed. Zelfs met D&B Max'en erop gaat het gewoon door!
                      d&b Audiotechnik
