hallo forum leden,
Ik had een vraagje het klinkt dom.
Ik heb de behringer ep1500, spec:
2 x 700 Watts into 2 Ohms; 1,400 Watts into 4 Ohms bridged operation
2-channel, parallel or bridged mono operating modes for flexible application
Independent limiters for each channel offer dependable protection against distortion
Precise signal and clip LED indicators to monitor performance
Selectable low-frequency filters (30 Hz or 50 Hz) remove distracting infra-sound frequencies
Professional connectors, compatible with Neutrik Speakon connectors, and "touch-proof" binding post loudspeaker outputs enable secure operation
Balanced XLR and 1/4" TRS inputs
Connection option for extra amps in parallel operation
Ultra-reliable Toshiba/Fairchild high-power transistors
High-current toroidal transformer for absolute reliability and lowest noise emission
“Back-to-front” ventilation system including air filter with automatically adjusting fan speed for smooth operation
Independent DC and thermal overload protection on each channel automatically protects amplifier and speakers
High-quality components and exceptionally rugged construction ensure long life
Maar hoeveel watt is dat op 8ohm?
Heeft iemand daar een formule of antwoordt op?
