Rcf woofer in Beyma kast
  • oversound
    • 218
    Goededag,
    Ik heb hier thuis nog 4 stuks rcf L15 P801 woofers liggen.
    Nu zag ik een aantal kasten op internet te koop staan .
    1 van die kasten is de enkel 15" baskast B09/9 van de beyma site.
    Zou het mogelijk zijn de rcf in deze kast te plaatsen?
    Testen is natuurlijk de beste manier maar ik doe lavast even een vooronderzoek.
    Hier de gegevens van de speaker.
    L15P801
    Typical characteristic
    Nominal Diameter 380 mm 15 Inch
    Rated Impedance 8 W
    Power handling capacity
    (1)
    350 Watts
    Sensitivity 1W, 1m
    (2)
    100 dB
    Frequency Range
    (3)
    54-5200 Hz
    Power Compression
    (4)
    @ -10dB power / dB
    @ - 3dB power / dB
    @ rated power / dB
    Distortion
    (5)
    2nd harmonic 1.5 %
    3nd harmonic 0.4 %
    Effective Piston Diameter 330 mm 13.0 Inch
    Maximum Excursion Before Damage (peak to peak) 30.5 mm 1.2 Inch
    Minimum Impedance 6.9 @ 250 Hz W
    Voice Coil Diameter 76 mm 3.0 Inch
    Voice Coil Material Copper
    Voice Coil Winding Depth 12 mm 0.5 Inch
    Number of layers 2
    Kind of layer round -outside
    Electrical polarity A positive voltage applied on the red terminal produces
    forward cone motion.
    Thickness Top Plate Depth 7.5 mm 0.3 Inch
    BL Factor BL 21.5 T x m
    Effective Moving Mass Mms 73 gr
    Thiele - Small Parameters
    (6)
    Resonance frequency Fs 44 Hz
    DC resistance Re 5.6 W
    Mechanical factor Qms 4.5
    Electrical factor Qes 0.25
    Total factor Qts 0.23
    Equivalent Cas air load Vas 180 liter
    Effettive piston area Sd 0.085 m
    2
    Max. linear excursion
    (7)
    Xmax 4.1 mm
    Linear displacement volume Vd 350.5 cm
    3
    Voice - coil inductance @ 1KHz Le1K 1.63 mH
    Half-space efficiency Eff 5.9 %
    Mounting Information
    Overall Diameter 387 mm 15.2 Inch
    Bolt Circle Diameter 371 mm 14.6 Inch
    Bolt Hole Diameter 6.5 mm 0.3 Inch
    Baffle Cutout Diameter
    Front Mount 355 mm 14.0 Inch
    Rear Mount 353 mm 13.9 Inch
    Depth 155 mm 6.1 Inch
    Volume Displaced by Driver 5.5 liter
    Net Weight 9.1 Kg
    Shipping Weight 10.2 Kg
    1
    AES standard (50-500) Hz.
    2
    Sensitivity is based on a 100-1000Hz pink noise signal for an in put 2.83V @ 8
    Ohms.
    3
    Frequency range is defined as the frequency extremes over which the response is
    -10dB relative to rated sensitivity.
    4
    Power compression is the sensitivity loss at the specified power,measured from
    50-500Hz,after a 5 minute AES standard
    pink noise preconditioning test at the specified power.
    5
    Distorsion is measured at -10dB rating power,from 100 to 500 Hz.
    6
    Thiele-Small parameter are measured after 2 hour exercise period using at the
    power handling capacity.
    7
    Mathematical Xmax
  • Banned
    Banned
    • 951
    Hee overdrive ....
    In theorie zou het moeten kunnen omdat de meeste bouwtekeningen van Beyma vrij neutraal zijn ( inhoud van box is meestal de benodigde literinhoud ) voor een 15 of 18incher alleen zou je met de tuning van de poort iets verschil hebben !
    Heb je de foto's al binnen ???
    • Rademakers
      • 1281
      In een basreflex komt deze speaker niet echt tot zijn recht, veel te efficient. Wel in korte hornloaded kasten of in topkasten. Waar werd de speaker eerst voor gebruikt?
      Mvg Johan
      • oversound
        • 218
        Heb vandaag de speakers kunnen testen in de kast bij collega. Ja op lage volumes klonk lekker en vol maar bij hogere volumes ging de speaker zich vreemd gedragen. Klonk niet meer zuiver enz. De 4 speakers kon ik tijdje geleden erg goedkoop op de kop tikken (nieuw staat). Ik heb ook twee Ohm br 215 kasten hier thuis staan en daar zit ook deze RCF in. Dat gaat kneiter hard, zuiver geluid, goede bass. Maar nu was ik dus aan kijken of voor de overige speakers nog compacte kastjes bestaan.
        Heeft iemand mischien ideeën kwa korte hornloaded kastjes? Of andere geschikte kastjes?
        Alvast erg bedankt voor de moeitje
        Emiel
