Hallo
weet iemand mischien wat over deze versterker:
alvast bedankt voor de reacties!
Groeten Patrick
Google Afbeeldingen resultaat voor http://www.e-commerce-live.net/images/product_images/thumbnail_images/1021_0.jpg
Power output 8ohm: 2x 1130W
Power output 4ohm: 2x 1810W
Frequency Response: 20Hz-20KHz@8ohm+0dB/-0.5dB
THD: 0.05%
Input Impedance: 20kilo ohm/10kilo ohm
Input Voltage/Frequency: ~230V±10%/50-60Hz
Output Class: Class D
Gross weight: 7 kg
- The X3 offers very high efficiency and delivers more power to the speaker. The output stages of the amplifiers typically run at 95% efficiency, dissipating only 5% of the input energy as heat.
- Superior Sound-sonic accuracy
Crystal-clear highs, and a tight, well-defined low end. It is the best choice for application in speech, meeting and clubs where needs light music.
-Totally Digital with High Reliability
The X3 is based on PWM technology. PWM provides high reliably, small size, low weight and high efficiency. A PWM converter works as a high frequency sampler, converting the variable amplitude (audio) signal into an impulse sequence with average value equal to the audio input.
- QSA’s legendary modular design, unibody welded chassis construction and conservative multiple protection circuits make the X-Series perfect for nearly every application.In addition to superior bass, excellent vocal and high frequency response highlight the features of this series hear the soundother amplifiers miss!
Groeten Patrick
THD: 0.05%
Gross weight: 7 kg
