Ik heb een vraag over deze hardware:
US Blaster MAX 7343
Is dit een degelijk apparaat (voor hoofdzakelijk thuisgebruik)
MAX 7343 - USB - SD - Dual Media Player - Scratch
Playing MP3 files was never easier!! With this compact double media player from US Blaster you can instantly play and mix from a USB stick⁄SD card or external hard drive, with all the functions of a regular CD player. Read your folders and tracks easily with the ID3 tag function.
Functions:
This innovative product gives the modern DJ lots of possibilities to work without CDs or records anywhere! The only thing you need is the MAX 7343, a USB stick, SD card or an external hard drive. No more big cases full of records and CDs. Every MP3 file you have can be played, this player is compatible with 16, 22.5, 24, 32, 44.1, 48 KHz with bitrates from 32 Kbps to 320 Kbps! The player is also equipped with various functions such as pitch, pitch bend, 3-band equalizer, folder search, loop⁄reloop function, and even ID3 tags! The ID3 tag function enables the player to display every detail of your files, such as title, author, time⁄remaining time and bitrate. This way you don’t need an inventory of your USB stick ⁄SD card or hard drive!
This media player is 100% shockproof. Just plug in your USB stick⁄SD card or hard drive, switch between the two and go for it! You can also search with folder search which has an option to skip 10 files to speed up your navigation. The new MAX 7343 is user friendly, fast, and equipped with the latest functions!
Specifications:
* Double media player with built-in mixer
* SCRATCH
* ID3 tag
* 2 cardreaders and 2 USB ports
* SD ⁄ USB switch for each channel
* Folder search
* Search mode with jogwheel
* Bright blue display
* SD card⁄USB⁄Phono⁄Line⁄Microphone inputs
* Pitch range: 16%
* 100% shock proof
* Seamless loop
* Time ⁄ program ⁄ repeat function
* Program up to 20 tracks
* +10 track search button
* Replaceable crossfader
* 2 RCA and 2 REC outputs
* 3-band equalizer
* MP3 decoding supports 16, 22.5, 24, 32, 44.1, 48 KHz with bitrates from 32 Kbps to 320 Kbps
* Pitch control (max. 16%)
* Adjustment range: +⁄- 12 dB
* Gain: 20 dB
* Frequency range: 20 Hz – 20 KHz
* Dimensions: 325 x 260 x 60 mm
* Weight: 3.8 Kg
US Blaster MAX 7343
Functions:
Specifications:
* SCRATCH
* ID3 tag
* Folder search
* Pitch range: 16%
* 100% shock proof
* Seamless loop
* 3-band equalizer
* Gain: 20 dB
* Weight: 3.8 Kg
