Hoi,
Ik ben nieuw in de wereld van licht en geluid en ik ben van plan een leuke set te kopen. Ik zit nu te denken aan een DAP DS CDJ 200 (dubbele cd speler met mixer). Maar ik kom net op internet hetvolgende tegen: Us-Blaster USB7338
Weet iemand of dit een goed systeem is? Is deze op de pc aan te sluiten en kan deze mp3 cd's afspelen?
Alvast bedankt.
Mvg Robbert
EDIT: Dit is de technische informatie die erbij staat:
Van de Us Blaster USB 7338:
Start mixing with our new US Blaster DJ set. The build-in mixer make this set "Ready to use". Technical spec.:
* 2 x 50 Watt RMS Amplifier
* 2x20 Sec Anti-shock with RAM buffer
* Pitch control with range of +⁄- 16%
* Integrated blue LCD display
* 14cm Jog Wheel makes searching easier
* Jog Dial
* Seamless loop
* Rotary tone controls (high⁄mid⁄low⁄gain)
* Stereo recording ⁄ monitor speakers output by XLR en 6.3 mm jackplug
* 6.3 mm jackplug headphone connector
* Audio CD and CD-R compatible
* Anti-Shock using RAM Buffer Memory
* Instant-Start and Cue with preview for each channel
* Single ⁄ Continuous play modes
* Robo-Start
* Fader-Start
* Pitch bend via Jog wheel or buttons
* Three time display modes
* Frame accurate search
* 10 Direct track access buttons
* +10 track button for quick navigation
* Fully programmable with repeat function
* 3-band EQ with Gain Control
* BPM Counter
* Assignable ⁄ removable crossfader
* Crossfader control CD Play and Pause
* LED output meters
* 482x122x260mm
Van de DAP DS DCJ 200:
The DS-CDJ200 combines a DJ mixer with 2 full-featured CD players in one compact unit. including 2 mic inputs with separate EQs, external inputs for 2 phono or 3 line inputs, EQs on each channel, true buffered instant start, seamless looping, blend headphone cue, and anti-shock technology. This self-contained unit is ideal for the DJ's main or backup system, or simple contractor install. Simply plug this unit into a set of powered speakers and your complete system is ready to go. Techniche info:
Power supply: 115/230V
Measurements: 480x260x130mm
Weight: 6.8kg Mixer:
2 channel/ 5 inputs (2x Line, 2x phono, 1x mic)
Frequency Response: 18HZ-22Khz
S/N Ratio 85dB
Distortion <0.1%
Eq hi/mid/low -20Db~+10Db
Headphones out at front side CD players:
Pitch +/- 12%
+ 10 search function for fast track access
Rubber function buttons
Anti shock, 40 seconds buffer
Big Cue and play buttons
Measurements: 482x122x260
Alvast bedankt.
Mvg Robbert
* Jog Dial
* Seamless loop
* Robo-Start
* Fader-Start
* BPM Counter
* LED output meters
* 482x122x260mm
S/N Ratio 85dB
Distortion <0.1%
Pitch +/- 12%
