Rock N`Rollercoaster @ Walt Disney Studio`s Paris
  • DJ_Compact
    • Jan 2004
    • 234
    Hoi,
    Wie kan mij wat meer info geven over de 'Rock N`Rollercoaster' in Parijs? Wie heeft het licht en trussing daar geplaatst? Voor het geval dat:
    De RnRC is een overdekte achtbaan waarbij je tijdens de rit muziek van Aerosmith te horen krijgt. In de hal is best veel trussing en licht te vinden. Dus voor wie meer info heeft: Bedankt!
    Mjaaaa....
  • johan L.
    • 384
    truss is van prolyte (fotos staan op de prolyte site)
    haze/fog is mgd en Walt Disney Imagineers
    Licht draait op 2 hog2 rackmount units
    Ook veel EAW daar.
    Heb er ergens wat meer info over liggen hier, moet alleen even in het argief duiken.
    Net deed ie het nog.
    • johan L.
      • 384
      Zoals beloofd,
      Byline: Ellen Lampert-Greaux
      Two attractions at Walt Disney Studios, the new gate at Disneyland Paris, are real standouts in the lighting department. Rock'n'Roller Coaster avec Aerosmith, a revised version of the original attraction at Disney World in Orlando, takes guests on a hair-raising ride through a rock concert, while Armageddon Special Effects (based on the film of the same name) takes place on a space shuttle during a meteor attack.
      A RUSH OF ROCK AND ROLL
      The storyline at Rock'n'Roller Coaster is that the guests are visiting the Tour de Force Records experimental test facility where a roller coaster is combined with truss, automated lights, and music by Aerosmith. "There are five ride vehicles, each with its own soundtrack and lighting program," explains Paula Dinkel, principal LD for Walt Disney Imagineering in Glendale, CA. Art director Stefan Hellwig, Dinkel, and a team of designers worked together to design the attraction, with the scenery consisting mostly of truss, props, and lights. The ride track passes through, over, around, and under towers of Prolyte truss and through two truss circles. Lighting equipment is mounted on the floors, walls, pipes, and towers.
      "The music and lighting are specific to each vehicle, and each one has its own color scheme," Dinkel explains. "Each car always has the same music and lighting program but the cars are put on the ride track in a different order." Dinkel gave each vehicle a nickname to go with the music and a color scheme - green/yellow, red/amber, pink/magenta, bright multicolors, and deep blue. For example, Vehicle #5 is blue and runs to Aerosmith's "Sweet Emotion," and Dinkel calls the lighting concept "starry night" as the car moves through blue-lit truss and an all-blue nighttime environment with High End Systems Dataflash [superscript][R] AF1000 strobes sparkling throughout the building creating the stars. The ride lasts about a minute and a half from load to unload.
      The challenge here is making sure that the right lighting accompanies each car. A custom control system designed by WDI syncs up the right music to each vehicle and then cues the right lighting at the various points along the ride. The intricate show audio, lighting, and ride control system uses track sensors, SMPTE and MIDI signals, and 12 universes of DMX to control over 400 automated lights.
      The lighting control system was designed by Ken Wagner, WDI lighting controls designer, and assistant LD Jason Killelea. The show was programmed on two Flying Pig Systems Wholehog [superscript][R] II consoles with expansion wings.
      There are three Wholehog rack-mount playback units that run the attraction on a day-to-day basis. The first is in the loading area and runs the lighting in the lobby, the queue line, the load/unload platform, and the outside marquee. Two more units are found in the ride portion of the attraction, known as the Gravity Building (perhaps since the guests are flying upside down at times). "These two playback units work together to run the lighting and control the motion and color of the fixtures," says Dinkel. "They are independent of the first one so that if the ride stops, the automated fixtures in the Gravity Building can stop as well, but the show lighting in the loading area can keep running.
      "It was a real group effort to make it all work," Dinkel continues, complimenting the work of Wagner, Killelea, and the Hog programmers. "We worked on the programming from September through Christmas, then again from January through March, until after the soft opening of the park." While programming inside the ride itself, the lighting team worked in a cage that provided a safe niche with clearance from the ride cars. "The vehicles would run while we were programming. Then we'd ask the operators to stop so we could come out to ride it to see what it looked like from the guest's point of view. I must have ridden it at least 1,000 times and I still feel the thrill of the launch," recalls Dinkel.
      The preshow area is designed as the lobby of the Tour
      • kokkie
        • 1166
        Volgens mij wordt alles geleverd door Lightco en zijn de de genoemde Hog operators van Tenfeet, Nederlands product dus!!!!
        • berolios
          • Sep 2005
          • 1538
          Jammer van dat ColorKnetter, hadden ze beter Xilver voor kunnen bellen...
          • DJ_Compact
            • Jan 2004
            • 234
            Bedankt Johan, ook bedankt dat je het stuk op TP hebt gezet. Nou, geen Martin dus zoals Kevin sugereerde.
            Trouwens, heeft je aparte kamer in The Manor nog goed geslapen?[)]
            Mjaaaa....
            • Fons
              • 67
              Het overgrote deel van de installatie van de zgn "entertainment lighting" in Disney Studios Parijs is gedaan door Flashlight. Het merendeel van het programmeren door Tenfeet. Truss in R&R Coaster is van Prolyte. Rookmachines in R&R zijn van Rosco. Alle dimmers van ETC.
              Projectmanager was ondergetekende
              Als je dus nog vragen hebt..
              Groet,
              Fons
              • LaGaffe
                • Sep 2004
                • 4
                citaat:Geplaatst door berolios
                Hmmm... jammer van je opmerking... Had xilver 4 jaar geleden toen het installeren begon al dat type fixture...??? Laat staan in de ontwerpfase, die zeker al een langere tijd daarvoor zal zijn begonnen.
                Eerst was er licht...
                • The original Lightman
                  • Sep 2005
                  • 1
                  En geïnstalleerd door Flashlight tech's !! en dat geldt voor meer rides... Binnenkort dus ook Buzz Lightyear waar Flashlight ook een aandeel in heeft gehad en de volgende komt er al weer aan.
                  [FONT=Times New Roman][FONT=Arial]"I can admire [/FONT][FONT=Arial]the pope, I can admire anyone who can tour for 20 years without ever releasing an album" [/FONT][/FONT]
                  [FONT=Arial][FONT=Times New Roman] [/FONT][/FONT]
                  [FONT=Arial][FONT=Times New Roman]Rita Rutner[/FONT][/FONT]
                  • masterblaster
                    hebben er zoveel bedrijven samengewerkt en geleverd of is iedereen in deze topic blij dat ze ook een naam weten van een lichtbedrijf. dus wie waren het nou flashlight, lightco of eaw?
                    • Fons
                      • 67
                      Het contract voor het leveren, installeren en programmeren van de helft van alle 'show-lighting' tijdens de bouw van het tweede park (Walt Disney Studios) is toendertijd gegund aan NOB-decor. Destijds een zusterbedrijf van Flashlight.
                      Tijdens de bouw kreeg NOB-decor steeds meer extra opdrachten en is het bedrijf dat de andere helft van de show-lighting deed afgehaakt.
                      Het leeuwendeel van de show-lighting in Walt Disney Studios is dus gedaan door NOB-decor, die overigens ook het decor voor Armageddon gemaakt hebben.
                      NOB-decor huurde Flashlight Rental voor het installatie werk, Flashlight Sales (= nu Lightco) voor het leveren van de materialen en Ten Feet in voor het programmeren.
                      Na opening van het park heeft NOB-decor, in samenwerking met bovenstaande bedrijven nog Art Attack en I-zone nog gebouwd/geinstalleerd/geprogrammeerd.
                      Er hebben tientallen mensen van Flashlight Rental en Ten Feet maandenlang in Parijs gezeten om deze klus te klaren. Alleen het programmeren van het licht van R&R Coaster duurde al meer dan drie maanden.
                      Ik was project manager, ingehuurd door NOB-decor, voor alle projecten.
                      Nog later heeft Lightco gewerkt aan de upgrade van Space Mountain en op dit moment word er door hen aan nog meer projecten gewerkt.
                      Als je nog vragen hebt hoor ik dat graag.
                      • kosi
                        • 40
                        Net terug van enkele dagen Disneyland.
                        Ik moet eerlijk bekennen dat de lightshow van de R&Rcoaster zeer zwak was.
                        Net voor het instappen van de coaster hangen die led armatuurtjes, daarbij waren er een reeks die wat raar deden (blijven hangen op bepaalde kleuren) van de movin heads waren er enkele die wel bewogen maar gewoon de lamp van stuk was. Tijdens de rit zelf 1 strobe gezien bij het vertrek en halverwege de rit een toren waar 4 strobes inzaten. Van intelligent licht zeer weinig gezien: in't totaal misschien 10 fixtures, hier en daar zag je nog een toestel hangen waar net genoeg licht uitkwam om de spiegel te verlichten...
                        Was teleurgesteld, doch het werk in de Space Mountain >>> echt knap.
                        -- Kosi --
                        • axs
                          • 2687
                          Naar wat ik las op Lightnetwork is de space mountain tijdelijk rockin' Space Mountain met een hoop aanpassingen
                          2x DL1
                          studiospot 250
                          pixel pars
                          custom made led fixtures
                          dit alles op een hog3 console
                          • kokkie
                            • 1166
                            Zeg AXS, gaat dat topic niet over Disneyland USA?
                            En wat het onderhoud betreft, daar zijn ze in Parijs niet zo goed in. Het zijn hun spullen, dus zouden ze het ook moeten onderhouden, maar het is inderdaad triest om door de Rock 'N Rollercoaster of Space Mountain te lopen en te weten hoe het eruit moet zien, maar dat er gewoon heel veel stuk is. Gelukkig alweer een jaar niet geweest.
                            • RWE
                              • 26
                              [QUOTE=kosi]Net terug van enkele dagen Disneyland.
                              Ja het blijven De Fransen die het onderhoud moeten uitvoeren, ik was er een jaar na installatie en het was toen al om te huilen, heb ik daar een half jaar voor gewerkt !
