Lem K-6
  • FiëstaLj
    • 2068
    Lem K-6
    Binnenkort krijgen we bij ons bedrijf een demosetje Lem K-6 in de truck te staan...
    Nou wilde ik alvast wat gebruikerservaringen horen.....
    Nou: brand maar los...
    Maar wij hebben LEM, bezoek de site
  • Rudy Vorstenbosch
    • Jun 2001
    • 1429
    info @ http://www.lemaudio.com/en/products/k/index.html
    Hey thijs.....heb het wel eens gehoord.
    Volgens mij is dit setje qwa aanhoren erg afhankelijk van de aansturing.
    Of gaat het om de actieve uitvoering?
    K 3
    K 6
    K L
    LOUDSPEAKER SPECIFICATIONS
    COMPONENTS
    1'' coaxial driver - 12" woofer
    1'' coaxial driver - 15" woofer
    15" woofer
    POWER HANDLING - (EIA RS-426A)
    300 W continuous - 600 W peak
    600 W continuous - 1200 W peak
    IMPEDANCE
    8 W
    8 W
    8 W
    PASSIVE CROSSOVER
    1800 Hz @ 12-18 dB/oct.
    1400 Hz @ 12-18 dB/oct.
    250 Hz @ 12 dB/oct.
    CONNECTIONS (passive versions)
    2 x 4-way SPEAKON (input + link)
    CONSTRUCTION
    12-ply plywood enclosure with scratch-resistant paint. Metal grid with polyurethane protection panel. 2 hanging points for M8 threaded hardware. K6 PRO e KL PRO: 4 six-position flying bars.
    DIMENSIONS (WxHxD)
    542x496x537 mm
    542x656x537 mm
    542x656x537 mm
    WEIGHT (passive / active)
    24 / 36 Kg
    34 / 47 Kg
    34 / 41,6 Kg
    AMPLIFIER SPECIFICATIONS (active versions)
    EIA OUTPUT POWER(1 KHz, max THD 1%)
    300 W
    550 W
    550 W
    IHF OUTPUT POWER (Tone burst 10%/20ms, max THD 0.1%)
    350 W
    600 W
    600 W
    INPUT SENSITIVITY
    0 dB (0.775V)
    0 dB (0.775V) LOW SPIN off
    -6 dB (0.387V) LOW SPIN on
    INPUT IMPEDANCE
    30 W (balanced) - 15 W (unbalanced)
    ACTIVE CROSSOVER
    From 80 Hz to 320 Hz @ 12db/oct.
    DISTORTION
    <0.02 % (THD+Noise)
    CONTROLS
    Volume - LIMITER ON/OFF - Earth lift - XOVER frequency (K L) - LOW SPIN ON/OFF (K L)
    DISPLAY
    SIGNAL/LIMIT LED- ON LED
    CONNECTIONS
    1 x COMBO (input) - 1 x XLR-M (link) - 1 x POWERCON (power supply)
    2 x COMBO (L&R in) - 2 x XLR-M (L&R xover out) - 2 x XLR-M (L&R link) - 2 x POWERCON (pwr+link)
    POWER SUPPLY
    see label on the apparatus
    SYSTEM SPECIFICATIONS
    SENSITIVITY (SPL 1W/1m)
    100 dB
    100 dB
    98 dB
    MAX SPL CONTINUOUS
    121 dB
    124 dB
    118 dB
    MAX SPL PEAK
    124 dB
    127 dB
    121 dB
    FREQUENCY RESPONSE
    65-20000 Hz (-10dB)
    52-20000 Hz (-10dB)
    40-320 Hz (-10dB)
    DISPERSION (OxV)
    60x60 °
    60x60 °
    <h5>Showtechniek</h5>
    • Leon_
      • 12
      Ik heb ze een keer gehoord maar toen was een van de coaxiaal speaker kapot.
      Dus kan niet echt zeggen hoe ze klinken.
      Qua uiterlijk vind ik de kasten een beetje kinderachtig. De klankkast is gemaakt van kunstof. Ik zou ze in ieder geval nooit kopen. Maarja dat is mijn mening.
      Als iemand nog interesse heeft in deze kasten 2x KL en 2xK6 ik weet er nog paar te koop te staan
      MVG Leon
      • FiëstaLj
        • 2068
        Ik denk dat wij de actieve versie krijgen.... aangezien we ook al axys arena hebben staan...
        Maar ik zal het de baas es vragen...
