RCF PA 281 speakers
  • frederic
    • 3511
    RCF PA 281 speakers
    Beste,
    Bij ons in de kerkgemeenschap hebben ze 4 RCF PA-281 toppen gekregen.
    Weet iemand of die speakers goed zijn om te gebruiken voor bands ?
    Op de specifiecatie geven ze 300w rms en 1200w piek bij 4 ohm.
    Welk vermogen zou je mogen gebruiken van versterker?
    Ik dacht van en Synq Digit 2k5 aan te schaffen.
    specifiecatie:
    [FONT=Interstate-Regular][FONT=Interstate-Regular][FONT=Interstate-Regular][LEFT]ELECTROACOUSTIC SPECIFICATIONS[/LEFT]
    [/FONT]
    [/FONT]
    [/FONT][FONT=Interstate-Light][FONT=Interstate-Light][FONT=Interstate-Light][LEFT]Tipology 2-way bass reflex speaker system
    RMS power handling 300 W
    Peak power handling 1200 W
    Nominal Impedance 4 Ohm
    Transducers LF: 2 x 8” carbon fiber woofers
    with 2” voice coil
    HF: 1” compression driver
    with 1”
    [/FONT]
    [/FONT]
    [/FONT][FONT=Interstate-Light][FONT=Interstate-Light][FONT=Interstate-Light]3/4 [/FONT][/FONT][/FONT][FONT=Interstate-Light][FONT=Interstate-Light][FONT=Interstate-Light]voice coil
    HF Horn type modified constant directivity
    Coverage pattern (-6 dB) 90° x 75°
    Frequency Response (
    [/FONT]
    [/FONT]
    [/FONT][FONT=HelveticaNeue-Light][FONT=HelveticaNeue-Light][FONT=HelveticaNeue-Light]±[/FONT][/FONT][/FONT][FONT=Interstate-Light][FONT=Interstate-Light][FONT=Interstate-Light]3 dB) 65 Hz – 18 kHz
    Sensitivity (1W / 1mt) 92 dB
    Max SPL (1 mt) 119 dB
    Crossover 2.1 kHz
    HF protection dynamic
    Connectors two NL4MP Speakon[/LEFT]
    [/FONT]
    [/FONT]
    [/FONT][FONT=Interstate-Regular][FONT=Interstate-Regular][FONT=Interstate-Regular][LEFT]CABINET SPECIFICATIONS[/LEFT]
    [/FONT]
    [/FONT]
    [/FONT][FONT=Interstate-Light][FONT=Interstate-Light][FONT=Interstate-Light][LEFT]Wood 19-mm multilayered birch
    Finishing black scratchproof painting
    Rigging hardware 5 x M10 - 4 x M8 insert points
    Dimensions (H x W x D) 770 x 304 x 327 mm
    Internal volume 47 l[/LEFT]
    Net weight 23 kg
    [/FONT]
    [/FONT]
    [/FONT]
  • Whitefarmer
    • 1244
    volgens mij bedoel je de 2K2 versterker, deze levert 1100 W bij 4 ohm (is dus wel erg aan de hoge kant voor 300 W speakertjes....) Ik weet zo niet wat die amp levert bij 8 ohm, wellicht kun je 2 speakers in serie zetten.
    Groeten John
      Ik denk dat de 2K2 een prima versterker is voor die speakers, dezelfde speakers gebruik ik in mijn line array. Speakers gaan niet snel kapot door teveel vermogen, wel door clippende (te lichte) versterkers. De beperkende factor zal waarschijnlijk het passieve cross-over zijn dat in de 281 zit.
      Een band over deze speakers zal zonder subs wat magertjes klinken, de kickdrum en bas gitaar zullen ze niet aankunnen.
      • 4AC
        • Nov 2007
        • 1791
        MusicXTRA kan er je alles over vertellen, maar misschien heb je hier nog wat aan: http://www.licht-geluid.nl/forum/liv...tor-8-mr8.html Bij mij overigens niet over gegaan tot aanschaf. Reden: verkocht.
        Mvg,
        Teun
        uǝɿɿɐʌǝ6ɯo sı ʇsʞǝʇ ǝzǝp
