Is er misschien iemand bekend met de omnitronic X series ?
Het gaat om het volgende:
Top Kasten:
LF rated power: 400 W RMS
MF rated power: 300 W RMS
HF rated power: 100 W RMS
Components: 15" woofer, 10" MF-horn, 2" HF-horn
Connections: One 4-pole Speaker-socket
Two 8-pole Speaker-sockets
LF Sensitivity (1 W/m): 102 dB
MF Sensitivity (1 W/m): 109 dB
HF Sensitivity (1 W/m): 112 dB
LF Max. SPL (1 m): 138 dB
MF Max. SPL (1 m): 141 dB
HF Max. SPL (1 m): 141 dB
Impedance: 8 Ohms
Frequency range: 95 Hz - 18 kHz
Dispersion angle (1 kHz): 40° x 35°/90° x 45°
Dimensions (H x W x D): 1020 x 610 x 790 mm
Weight: 110 kg
En deze baskasten:
Rated power: 1000 W RMS
Bass: 2x18"
Connections: 2 Speaker-sockets
Sensitivity (1 W/m): 103 dB
Max. SPL (1 m): 136 dB
Impedance: 4 Ohms
Frequency range: 50 - 100 Hz
Weight: 100 kg
Top Kasten:
Impedance: 8 Ohms
Weight: 110 kg
En deze baskasten:
Bass: 2x18"
Impedance: 4 Ohms
Weight: 100 kg
