Goed ik na een tijdje forummen aardig wat wijzer geworden, nu loop ik ergens tegen een aanbod van een yamaha versterker aan: Yamaha 2700
Met de volgende specs:
Power output level
Stereo 8 ohms 350W + 350 W (2700) Stereo 4 ohms 500 W+ 500 W (P2700) (except Canadian model) Mono 8 ohms 1000 W (P2700) (except Canadian model)
Frequency response
Stereo @ 8 ohms, 1W. 10 Hz- 50 kHz. 0dB + 0.5, -1.5dB
Total harmonic distortion
Stereo 175 W (P2700) 20 Hz-20kHz
Intermodulation distortion
Stereo, 175W (P2700) 60 Hz:7kHz= 4.1.
Channel separation (Input level minimum)
175W (P2700) 1kHz @ 8 ohms. >/=80dB 175W (P2700) 20 Hz- 20 kHz @ 8 ohms >/= 70 dB
Damping factor
1kHz @ 8 ohms. > 100.
S/N
Input shorted @ 12.7kHz LPF. >/=100dB Input shorted @ IHF-A. >/= 110dB
Slew rate
Stereo 8 ohms full swing. +/- 40V/mms (P2700) Mono, 8 ohms, full swing. +/- 50 V/mms (P2700)
Input sensitivity
To produce 350W (P2700) into 8 ohms +4dB (1.23Vr.m.s.)
Maximum voltage gain
Input level maximum 32.5dB
Indicators
Green signal LED. 4 OHMS, 1W. Red clip LED. Illuminates when output distortion exceeds approx 1%. Red protection LED> Illuminates during protection or muting circuit operation. Red pilot LED. Illuminates when power on.
Protection units
Muting. 6 sec (+/-2 sec after power on. DC sensing. DC +/- 2 V output voltage. PC limiter. RL
Cooling fan speed circuit
All temperatures refer to heat sink temperature. Low speed /= 70 deg. C.
Front panel controls
Power Switch-push-type. 31-detent input attenuators x 2.
Rear Panel Control
Stereo/Mono mode switch (except P2700 Canadian model).
Power requirements
General model. 220/240V AC 50/60 Hz. USA.
Power consumption
General and USA models. 1000W
Dimensions
(Including feet) ( W x H x D). (depth behind front panel) 480 x 143.5 x 435.2 (mm) 18.9 x 5.6 x 17.1 (in). {400.2mm (15.75 in} (excluding feet) (W x H x D) {depth behind front panel } 480 x 132 x 435.2 (mm) 18.9 x 5.2 x 17.1 (in). {400.2 mm (15.75 in)}
Weight
24kg (53lbs)
Leuk idee om daar 2 subs a 500watt aan te sturen als beginnetje? Ik heb namelijk niet zoveel herrie als die 500w nodig.. die 350 is in princiepe best leuk?
Nou komt de clue natuurlijk is elke versterker wel geschikt om een sub aan te sturen... Had ooit een yamaha 2x150 wat versterker met 2x100w midtoners (2 way) maar die versterker is letterlijk in rook opgegaan...
Verders wat bedoelen ze nu met die 175 watt is dat zijn vermogen en 350 watt het piek vermogen?
Power output level
Frequency response
Damping factor
S/N
Slew rate
Input sensitivity
Indicators
Protection units
Rear Panel Control
Power requirements
Power consumption
Dimensions
Weight
24kg (53lbs)
