professionele MP3 players
  • Controller
    • 745
    Zijn er al veel professionele MP3 players waaronder ook 19inch versies.
    Hebben jullie er goede ervaringen mee met MP3 players?
    Ik heb er hier een van Numark gevonden.
    MPCD3 MP3 player single CD Prijs € 378,-
    -Single rack mount CD/MP3 player
    -Plays MP3 files from CDR and audio CDs
    -999 track index
    -Handheld wireless remote control
    -Direct track access with sequence programming
    -Interactive pitch bend/search wheel with finger grip
    -±8/16% pitch ranges
    -Digital output
    MPCD33 MP3 player dual CD Prijs € 855,-
    -Dual rack mountable CD player
    -Plays and pitches MP3 files from CDR
    -20 seconds Anti-Shock™, true buffered instant start
    -Interactive pitch/search wheel with finger grip
    -±8/16% pitch, sleep mode, BPM counter
    -Light up play/cue buttons
    -Direct track access, track sequence program
    -Additional rotary track access
    -Transport bay illumination light, CDR compatible
    -Relay play, 6-way fader/remote start/pause or start/recue
    -Digital output, power switch protector
    Zijn hier goede prijs/kwaliteit verhoudingen?
    Mochten jullie er meer vinden zet ze er maar bij en eventueel de prijs ook.
    Dit moet dus een verzameltopic worden van MP3 players met meningen, info, etc.
  • axs
    • Jun 2002
    • 2687
    Denon DN-4000, Denon DN-D9000
    De groe(n)ten
    Tom Manshoven
    • Controller
      • 745
      Nog een paar:
      Gemini DJ
      MP-3000XPrijs: € 849,-
      -Dual Pro Digital MP3 CD & Audio CD Player
      -All functions available to mix with MP3 discs: cue, pitch, loop, and bend
      -Anti-Shock buffer memory
      -Pitch Control with selectable +/- 4%, 8%, 16% range
      -Pitch Bend buttons
      -Search Mode selector for music search or track search
      -Robo-Start
      -Inner/Outer Jog Wheel for frame-accurate music
      -ADCS Automatic Disc Calibration System search and for ultra-fast track search
      -High-visibility blue LCD display
      -Loop with real-time loop editing
      -Decodes Compression up to 320 Kbps, better than any MP3 player out there
      MP-320X
      -Tabletop Digital MP3 CD & Audio CD Media Player
      -Looping
      -All Functions Available to Mix with MP3 Discs or CD's: Cue, Loop, &pitch with Bend
      -Anti-Shock Buffer Memory
      -Pitch Control +/- 10% Range
      -Search Mode Selector for Music or Track Search
      -Large Jog Wheel for Frame Accurate Music & Ultra Fast Track Search
      (ADCS Reads CDR's & Adjusts the Player for Disc Format)
      -High-Visibility Blue LCD Display
      -Pitch Bend Buttons
      MP-350X
      -Frontload Digital MP3 CD & Audio CD Media Player
      -All functions available to mix with CD's and/or MP3 files
      -Instant Start
      -Frame Accurate
      -Blue LED display
      -Pitch Bend buttons
      -Large Jog Wheel for frame-accurate music search and ultra-fast track search
      -Looping (Seamless in CD mode)
      • lifesound
        • 1052
        professioneel én MP3 ... dat zal wat mij betreft nooit samengaan...
        Ik ben geen klankman, ik doe alsof!
        • Roeltej
          • 761
          Opzich wel, maar dan zit je aan systemen als Encore vast.
          Met dit systeem moet je wel cd's gaan branden, aangezien er nog geen albums ed als MP3 op cd gezet worden.
          Mocht je zo'n speler aan willen schaffen, neem er dan wel een die je kan flashen, geloof dat de Denon's dat kunnen, zodat je later ook bv WMA, MP3pro en OGG af kan spelen ... + evt toekomstige standaarden.
          Aangezien MP3 eigenlijk een al veroudert systeem is.
          citaat:-Transport bay illumination light, CDR compatible
          Mja, uh, maak eens niet CDR compatible, maar wel mp3s af laten spelen.
          Vitality Show dot en el
          Vitality Show
          • Controller
            • 745
            Denon
            DN-D4000
            [u]MP3 Playback </u>
            - Supports V.B.R & C.B.R
            - Folder/File search
            - ID3-Tag display (Artist, Album & Title)
            - Play List Compatible (.m3u form)
            -2 Seamless Loops (per drive)
            -Shock Proof Memory (Audio CD: 10 sec., MP3: 100 sec.)
            -Pitch Bend (±18%)
            -Rotary Track Select Knob
            -Digital Outputs: SPDIF
            -Relay Playback
            -CD-R/RW Disc Playback
            -The DN-D4000 plays finalized CD-R/RW discs.
            [u]CD TEXT display</u>
            -Artist and track names can be displayed.
            -Most popular CD-R/RW burning software programs give you the ability to add CD TEXT.
            -2 Hot Starts & Stutter Cue Points (per drive)
            -Brake Effect
            -Pitch Control (±4.0%, ±10.0% or ±16.0%)
            -Fader Start
            -Disc Tray LED
            -Firmware Upgradable by CD-ROM Disc
            Pioneer
            DMP-555
            http://www.licht-geluid.nl/diversen/...eer-dmp555.jpg
            -SD Card
            The all new powerful, flexible and removable digital media. DMP-555 supports SD Audio format of SD Card.
            -MP3 Player
            The first ever DJ CD player with onboard MP3 capability. Compatible with CD-DA, CD-R, CD-RW and SD Card MP3 compression.
            -Dual Synchronous Play
            -Playback from both CD and SD Card sources. Mix MP3 loops and samples from the SD Card with CD-DA audio.
            -3-Band Isolator
            From either CD or SD Card, cut out any one of the three frequencies (low: 280Hz and below, mid: 280Hz-6Khz, high: 6Khz and above).
            -CD and SD Card Control Panels
            Separate and dedicated panels for control of each source during Dual Synchronous Play, with all the usual Pioneer CDJ player functions.
            -SD Card Tempo
            Adjustment of SD Card BPM for Dual Play.
            -SD Card Pitch Bend
            Adjust the pitch of a loop or sample on SD Card during Dual Synchronous Play.
            -SD Card Mixout Control
            Mixes SD Card audio output with your CD audio playout during Synchronous Play.
            -SD Card Synchro
            Match and lock SD Card BPM to CD playout BPM, at the touch of a button during Synchronous Play.
            -SD Card Folder Search
            Navigate easily through SD Card contents. One Track Loop Set, Continuous loop of audio track on SD Card or CD.
            • splash
              • 342
              • Controller
                • 745
                we hebben het hier over hardware componenten niet over software
                  Laat BPM nu ook een 19" controler hebben <img src=icon_smile_big.gif border=0 align=middle>
                  De relevantie van deze opsomming (google is meer volledig...) ontgaat mij even.
                  • splash
                    • 342
                    Dankjewel mod! <img src=icon_smile_approve.gif border=0 align=middle>
