Dateq Vibe
  • pro`d`user
    • 534
    Dateq Vibe
    Dateq komt met een vervanger voor de XTC genaamd: Vibe
    Ik vind het een mixer die erg lijkt om de A&H Xone (en vele andere) maar ik ben benieuwd.
    Niet echt wat je verwacht van Dateq zo'n mixer maar desondanks hoop ik op de kwaliteit die je verwacht bij het merknaam Dateq.
    [quote]citaat:
    The long awaited professional DJ mixer has finally arrived !
    The Vibe has five channels, four of which are equipped with faders. The channel without fader is meant to enable microphones or auxiliary sources to be used without occupying one of the 4 main channels. In total 9 stereo sources and one microphone input is available. Microphone level can still be adjusted with the Gain-control, and a special “Rap” switch makes it possible to turn very quickly to the preset level of that channel. The fader channels are equipped with medium length, 60 mm ALPS fader which runs extremely smoothly. The VIBE channels consist of two inputs each, so that line signals such as computer, sampler, CD or MD player can be connected as well as three turntables. A push button next to the channel input control allows switching from input 1 to input 2, so that plugging in and unplugging equipment is a thing of the past.
    <!--[if !supportEmptyParas]--> <!--[endif]-->
    The tone control is just what can be expected from Dateq. A perfect Top for accentuating high hats, an aggressive Mid and a Groovy Bass. Top and Bass have a range of plus 8 to minus 32 dB, while the Mid band can be adjusted from minus 34 to plus 6 dB. So the need for kill switches is eliminated.
    The first microphone channel has a dedicated 4-way tone control with a sub-low band, to eliminate the ultra low “plop” frequencies and still maintain a warm full sound.
    A processor makes it possible to tune your Vibe mixer to your personal taste in control settings.
    This way you can personalize your own personal DJ tool.
    The X-fader is selectable between the four fader-channels of the Vibe and is together with the channel faders VCA operated, in order to exclude noise and to guarantee years of trouble-free use.
    The two Multi Band Filters are designed for changing the music just way you would like it.
    By using two filters at a time, spectacular mixes between two different sources can be created.
    The control of the filters can be done through manual rotation or by the cross-fader.
    To add even more flexibility each fader channel can choose to switch in the send/return path to allow external effects to be connected for optimum performance. To make it complete, a separate 20 segments VU meter can show the input and output level of the FX line.!
    This allows you to add external effects without the unwanted distortion, due to a too high level.
    Each channel can be monitored on a powerful headphone-output. Split, a unique Dateq function, can be tuned from the full Source, to the full Cue signal.
    This allows monitoring and listening to the master signal to be carried out on the headphones simultaneously.
    There are plenty of outputs available on the Vibe. The master output is balanced and has XLR plugs so that it can be coupled directly to an output amplifier. The master also has a cinch output. The XTC has a monitor out, a Sub low output for operation of an (active) low speaker and a second headphone connection.
    Also a RJ45 socket is provide to allow fast software updates in the future. A MIDI connection allows you to personalize start/stop settings to computers etc.
    Because the Vibe is used mostly in dimly lit surroundin
    Barry K.
    Wij werken met EV ole ole
  • Speakertje
    • Mar 2005
    • 462
    Ziet er leuk uit dat mixertje. Is er toevallig al bekend wat de advies prijzen zijn?
    M.v.g. Sander
    Nieuw SB122 en Dynacord S1200
    • tha_dj
      • Jan 2004
      • 375
      Inderdaad een relaxte tussen ligger van een XTC en een Apollo of andere dateq.......kan je als DJ 2 draaitafels en 2 cd spelers in je set-up aansluiten zonder te moeten switchen.......EN je kan de microfoon enigzins bijstellen van een MC.....
      your light !
      • pro`d`user
        • 534
        Denk dat dit absoluut niet een tussenligger is van een XTC en een Apollo.
        Denk eerder dat Dateq zich in de scene van dj-mixers met effecten wil gaan mengen
        zoals de Technics, Denon, A&H, Pioneer.
        Adviesprijs was volgens mij 1100-1200 euro, maar daar ben ik niet helemaal zeker van ik zal het nog even navragen.
        Barry K.
        • Speakertje
          • Mar 2005
          • 462
          citaat:Geplaatst door pro`d`user
          Wat voor effecten zitten er zoal op? Kan het uit de uitleg niet echt opmaken. Voor dat geld heb je een goeie mixer in handen met och best wel wat opties.
          M.v.g. Sander
          • admin
            Administrator
            • 1009
            Niet echt als aanvulling, maar meer ter info:
            http://www.licht-geluid.nl/nieuws/te...d=107&zoneid=7
            Al Bundy : If you want something fixed right, get an ugly guy to do it.
            • pro`d`user
              • 534
              citaate Dateq "VIBE" nadert zijn voltooiing.
              Samenwerking met grote namen uit de DJ scene hebben geleid tot een prachtige 4+1 mengtafel. Deze "Battlemixer" is het antwoord op de vraag naar een goed klinkende betrouwbare professionele DJ mixer!
              Deze Vibe kan door middel van een processor worden afgesteld tot een volledig naar de eigen hand van de DJ afgestelde "DJ Tool" Hij is voorzien van 5 kanalen, 10 ingangen met 1 speciaal "Rap"kanaal en een 4-voudige afwijkende toonregeling speciaal voor vocalen.
              De overige lijnkanalen zijn voorzien van 4 VCA gestuurde 60mm faders die diverse mix stijlen mogelijk maken. De Vibe heeft een ultra diepe DJ-style toonregeling meegekregen die een goede aanvulling zijn op de laatste mixing-trends.
              In totaal kunnen er op deze 4 kanalen 3 draaitafels en 5 lijnbronnen aangesloten worden. De phono ingangen kunnen eventueel naar lijningang worden omgezet.
              Om de flexibiliteit van de mixer te vergroten zijn er twee 5-voudige filterbanken toegepast die voor de meest uiteenlopende effecten kunnen zorgen!
              Iedere DJ wil zijn eigen geluid, en daaraan is er hiermee gehoor gegeven door ieder kanaal van een selecteerbare FX send/return te voorzien. Natuurlijk ontbreekt er een aparte VU meter voor het voorafluister signaal niet. Bovendien kan deze ook worden gebruikt om de Send/Return loop te monitoren, om zo het meest zuivere geluid te kunnen behouden.
              We kunnen nu nog niet alle andere spannende features noemen, maar de Vibe nodigt zeker uit tot nader onderzoek!
              Ik hoop dat je uit bovenstaand stuk wat wijzer kan worden over het effect gedeelte.
              Barry K.
              • Bastisito
                • Sep 2004
                • 185
                Niet gewend van Dateq. Hun handelsmerk was toch dat ze ontzettend hufter-proof mixers maakte die enorm overzichtelijk waren zonder al die poespas. Dan vind ik dit een pislelijk ding die ook nog eens veel te vol met knopjes zit (lijkt behringer wel ). Die kortere faders hadden ze gerust mogen verlengen van mij.
                Meneer, waar is dat ene knopje nou precies voor?
