Showtec Led light bar 16
  • admin
    Administrator
    • 1009
    Led Light Bar 16
    Inexpensive batten effect
    16 sections
    Power and data in- and output
    Compact size
    The LED Light bar 16 is a new member of the LED Light Bar range. It is equipped with 240 pieces 10 mm LED in Red, Green and Blue color. A great advantage of this bar is that it is divided in 16 sections which allows you to create beautiful flows and great chases. It has multiple DMX modes for optimal control as well as sound to light function for easy applications. The LED Light Bar 16 offers you a true value for money.
    Specifications
    Output:
    Lumens: 800
    Lux @2m: 613,3
    Max. Distance: 15m
    Light Source:
    LED System: 240 (96 red,72 green, 72 blue)
    10 mm LED's
    Drive Current: 25mA
    Refresh rate: 400Hz
    Color Range: RGB
    Electrical:
    Power Supply: 100-240V AC
    Power Consumption: 36W
    Control:
    Control Mode: DMX512
    DMX channels: 3, 5, 6, 12, 24, 48
    Optical system:
    Dimmer: 0-100%
    Strobe: 0-20Hz
    Beam Angle: 30°
    Physical:
    Dimensions: 1070 x 65 x 88 mm
    Weight: 2,6 kg
    Housing: Aluminum
    Color: black
    Power Connectors: IEC
    Data Connectors: XLR 3pole
    Cooling: Aluminum housing
    Safety:
    Operation temperature: -20~40°C
    Lees meer over de Showtec Led light bar 16
    Al Bundy : If you want something fixed right, get an ugly guy to do it.
