COM-41
Beltpack UHF Wireless Instrument Set
Plug and play
Low battery indication
Guitar cable lavelier microphone and headset included
The COM-41 wireless beltpack is a plug and play wireless starter package. It works on one frequency and it has no advanced menu's and settings. This is the easiest way to get started with wireless systems and it will always work. The beltpack transmitter has an indication to warn you when your batteries run low. The package includes a guitar cable (active guitars only), lavelier microphone and headset so this set will offer you everything you need for many applications.
Specifications
Modulation: FM with true diversity
Frequency: 865 Mhz
Frequency responce: 50Hz - 18Khz
THD: < 1,0 % (1Khz)
Maximum distance: Up to 50 meters
Receiver::
Indications: Antenna AB, AF signal
Controls: On/Off switch, volume, sqelch
Audio outputs: XLR male balanced, 1/4" jack unbalanced
Power supply: DC 12--15V 300mA
Dimensions: 47 x 210 x 160 mm (HxWxD)
Weight: 0,4 Kg
Transmitter
Connector: 3,5mm jack
Input impedance: 4Kohm
Headset mic: Condenser, cardiod
Lavelier mic: Condenser, cardiod
Indications: Low battery
Controls: On/Off/Standby switch, Squelch
RF output power: 10mW
Battery: 9V Block
Dimensions: 108 x 64 247 mm (HxWxD)
Weight: 0,1 Kg
Lees meer over de DAP Audio Com-41 beltpack uhf wireless instrument set
